This is my first post, so I hope I'm doing this right. I love my Evinrude but she'll jump out of gear at high speed, like hitting a log. I pulled the lower and replaced the forward gear and clutch dog, adjusted the shifter so that both forward and reverse have the same "throw". After further investigation, I found that the shifter (when the shifter detent is disengaged) has more room to move both forward and reverse. This tells me the clutch dog is not engaging fully into either gear. I inspected the connection between the lower shift rod and the upper rod and all was tight. It's like - if the shift rod were a bit longer, it would then engage fully. Am I missing something here?
