bigdaddyclint
Thread starter- Joined
- May 16, 2022
- 9
Morning all long time lurker first time poster. I have a quick question about a rebuild that I'm a quarter of the way through. Question I have is what can I get away with just cleaning up if it's not broken when it comes to a rebuild currently I'm getting new pistons, seals, most gaskets if not all of them. I'm wondering about if I should just purchase lifters rods and hydraulic lifters for it all or can I get away with reusing them. I noticed on the hydraulic lifters there's differences in play when I blow air into the small hole on the lifter some come up farther so go down farther some you can barely see the split in the hole. If I buy new hydraulic lifters will it affect anything with the rods I know that I'm going to have to re-adjust everything. Also when I pulled the hydraulic lifters out I did not keep them in order so I'm kind of worried about that not sure if I need to be I have not started on the head and taking out the valves and cleaning them I do know that I need to keep them in order. But what if I just go ahead amd get everything new how will that affect everything? So I guess at the end of the day I'm asking what can I salvage from the head/lifter area? And if I replace certain things what will I have to compensate for I guess. I'm also doing The speedy sleeve fix on the camshaft there are two grooves on there. Piston walls don't look too bad I'm really hoping that I don't get it all back together and have **** compression but if I have to I'll just take everything back apart and get it reboard out and find some oversized pistons. Thanks for any and all information you may be able to give me.
