New bow board
18trapper
Is it possible to replace this bow board without taking off the gunnels or the bow top aluminum? I can’t see any way to get a new full length board in there. The board is rotten to the point where the screws that hold on the trim have nothing to bite into. I’ve already painted the gunnels and really don’t want to take them off
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Here is what my SS16 looked like for reference
SHSU
BWR1953
I had to replace mine as well, but I didn't remove the sheet panels. And that was a major mistake. It took me forever to fabricate a replacement which worked. I got it done, but don't recommend that route.
I'd say bite the bullet, pull the panels and fab up your new piece. It'll be easier in the long run. :)
MNhunter1
Yeah, only way to do it properly is to remove the bow cap if you want to keep it one piece. I've replaced all mine with 3/4" ACX ply, sealed in either epoxy or spar, and wrapped with marine vinyl.
18trapper
well it looks like I’ll be tearing apart my boat even more than I planned to. I’ve been at that point more than once in this restoration
18trapper
Another question about the bow area. What or how is the bow seating setup from factory? My boat (ss16) was all dismantled when it was given to me so I wasn’t sure if there was plywood riveted to the supports then the bow seat cushions just rest on top of the plywood? Hope that question makes sense
SHSU
Sealed and covered plywood riveted to the frame. If we built pads, they would rest on top.
SHSU
