Lower
- Joined
- Sep 28, 2016
- 124
Yea and the old solenoid was definitely the problem but the two new ones won’t pass power-it will start and everything but will not pass power when trim switch is activated. No fuses/relays aside from the in-line shown. 3wire trim switch and only uses one solenoidrelays need battery from the fuse and proper grounding to be activated. did you check fuses etc...
do you see +12 reach the relays ??
I cut out the switch and touched red(power) to green which obviously works but touching to blue won’t. Which tells me it’s not the switch, correct?make certain the other side of the control relay winding is properly grounded ... no ground no current flow in the winding !!
12.42 volts mean nothing if the control path wire 12 v source is resistive to & from the trim switch
... try applying pure 12v of the battery on the control post to see if the properly grounded relay reacts
... if ok then the12.4v you measure is not passing the necessary amps to cause the relay to operate.. check for oxydized junctions, bad trim switch contacts etc...
you would be very bad lucky to have so many bad relays " the two new ones won’t pass power !!!"
Edit***Etlr78c not F.It’s a johnson 85hp javelin tilt and trim and I’m looking at the model # Ftlr78c so I’m guessing it’s a 1978?
Yep that’s itso 3 wire T&T
Right.The solenoid is used for UP only.-----For DOWN the current is lower and solenoid is not used.
It all keeps boiling down to the relay. The motor works fine in both directions with direct voltage. Is there any chance that an automotive relay is to blame vs a marine relay?on some 3 wireT&T black to motor never gets switched so 2 wires remain
blue and green applying power to either one individulally should produce up or down motions if not wires to motor or motor defective.
the rest is simple relay operation.. one winding is grounded the other is energized by =12v.... in some systmes the relay can be activated by having a perm. 12v on one post and applying ground to the other post. not to many choices.
applying a ohmeter across the two in-out main posts you should see a short when the relay is energized .
