salvageyard saviour
Thread starter- Joined
- Oct 28, 2018
- 174
These are new to me and I think I burnt the isolator. Guest 2111 switch and 2401 isolator.
Using one battery only and connected to 2 position of switch.
While trying to do carburetor work on a 1968, 283ci 210hp OMC. After running long enough to reach operating temp the volts climbed to full field (16+). Alternator and ballast were very hot to touch.
Assumed external regulator is bad. Installed a used one from a 73 OMC but accidentally left the sense wire poorly connected.
Voltage started okay then got very erratic. Shut down right away. Fixed connector. Now no power from isolator. Did the surge fry it?
I moved battery to #1 position on switch, still no power from isolator. Moved wire connected to output of isolator to output of #1 from switch. (Bypassing isolator)Works.
Can I use just the switch? Or should I buy another isolator? What's the benefits of both?
