4.3XL mercruiser inboard stern drive stalling at 4Krpm no surge, will not go any faster once stalled,
Eli W
So the float was sticking at high rpm’s on this 97 caravelle I just bought. So thought I would just buy a new carb. Carb fit perfect. Boat ran great for an hour. Then at about 45mph I adjusted the trim and heard a noise like a thumping jolting noise. Slowed down and realized the noise when I hit the trim only happens at higher speed.so I thought ok. Won’t do that anymore at higher rpm’s. All was well. The. I went to speed up and at 4K rpm’s I hear a noise, maybe carb backfire? Coming from the engine almost like a dull popping noise and the boat stalls. If I keep accelerating the boat almost dies. Once at 4K rpm’s it will not go any faster and stalls. Brand new carb. Is it maybe an adjustment issue in the carb. I saw nothing funny going on with my dials. And the boat runs great at 3.8 rpm’s. But at 4rpms the above problems occurs. Thanks for any advice.
Ayuh,..... Welcome Aboard,.... Did you change the fuel filter,..??
If not, pull it, 'n check it's Contents for anything but clean fresh gasoline,....
I suspect you pumped nasty gas into yer brand new carb,.....
Ya might need to pull it, 'n rebuild it,....
