2006 Glastron 205 with a Volvo Penta 5.0 GXi and SX Outdrive.
I’m looking for advice and/or experience with multiple gauge malfunction. All of my gauges, with the exception of the speedometer display incorrect readings. Examples include: tach jumps all over at an idol, temp gauges shows 180 degrees upon a cold start, voltmeter reads 10v but I read 13v at both the alternator and across the battery terminals. The gauges are all individual and separately replaceable.
Given the multiple simultaneous errors I assume there is a common issue impacting them all. I ran through some basic troubleshooting but am open to suggestions. To date I have:
Thanks!
Nathaniel
- Cleaned battery terminal connections.
- There appears to be a ground that runs from the battery to under the steering wheel / gauges. I removed the main ground there and removed the wire and ensured it was a good contact. It also looks like all the individual grounds use spade plugs off the main ground block. I removed and reseated all those.
- I checked all the fuses I could see and they all look good
- I checked connections at the back of the gauges and all looked good. I don’t think this is the issue though given all the gauges are problematic
Thanks!
Nathaniel
