Spark plugs for older Merc (80s)?
dwco5051
The Part# given ThomW in Post #3 is correct
As for the Plug Wires, I never grounded them, and I never got a shock while checking compression. I have gotten plenty of shocks while touching the Wires, attached to the plugs, when the engine was running
Ever have that fireball pass you when a loose wire made a spark and ignited the discharge from a cylinder near the one you were testing? Haven't had that happen in a long time since most of the newer boats have kill switches. Just have remember to pull the cord out now.
flyingscott
this is what you need. this is the service bulletin on spark plugs for your motor.
  • Mercury service bulletin (1) (1).pdf
Dave1027
I remember seeing a tech bulletin like this for my 100 hp years ago. I tried the gapped plugs but found they did not seem to hole shot as well so I went back to the surface gapped plugs.
flyingscott
It is the same one.
jimmbo
Starting in the mid 60s, thru the 80s a majority of engines used Surface Gap Plugs. They were touted as being less prone to causing Preignition than Conventional Plugs as they were a very Cold Plug. And though that could cause Fouling, it was advertised that the very High Voltage of the then current Ignition Systems, would still fire the Plugs. I had them on several outboards and never had any trouble. My 84 Merc 115, had over 1500 hrs on the original Plugs when I traded it in 14 yrs later for a 98 FICHT. That thing went thru dozens of Plugs the 4 years I owned it. But since OMC was paying for them, I wasn't too concerned. My Dads 1980 Evinrude's Owners Manual made reference to a Conventional Plug that was recommended if the engine was used at very low speeds continuously, otherwise the Surface Gap was to be used.
Robbyracks
So I'm a bit confused...I ordered Champion 827 L76V plugs. Should I not use these?
Am I now going with NGK BP8H-N-10 OR BPZ8H-N-10 ? These are a lot more expensive by me...
Robbyracks
Actually, the BP8H-N-10 is only $4.99 a plug. That's cheaper than all the other plugs I looked at. So this is the one I should get or the BPZ8H-N-10 (which is quite a bit more)?
Robbyracks
Also when performing a compression test should I disengage the fuel line?
Robbyracks
I performed a compression test -n 130 and 135-40 ish on the other.. changed lower unit oil, changed fuel filter and spark plugs... engine is running beter! Feeling pretty goo about that! I am by no means a technical person! so thanks for your help, folks...
