ghostgixxer
- Joined
- Jun 24, 2020
- 13
Hi folks !! First I want to apologize for the long text but I want to explain the issue I’m having in full details
!! Bought a new boat 2 days ago , the guy said in the add : boat is running great used it about 40 times last season , since he has moved about 1 hour and a half away from the marina recently he had the marina guys to do a quick summer tune up for him (oil , oil filter and fuel/water separator filter, new plugs and they saw a cracked ignition wire so they’ve changed all 4 , then parked it at his dock in the water . Met the guy at the marina , first did a compression test (all good on all 4) and quick visual inspection, started the engine (fired up right away and idle was top notch) let it idled for 5-8 mins (temp was ok) shut it down and looked the oil to see any signs of water getting in there (cracked block) everything was good so far . Restarted the engine and took it out the marina bay in gear at idle speed (no wake zone is about 4-5 minutes ride) , went for 1/4 throttle for 2 mins to slowly gain speed while still be able to listen for any weird noises coming out the engine (everything ok so far) , pinned it full throttle, pulled strong for about 2-3 seconds then lost most of its power within another 2-3 seconds !! Put it in neutral , bugged slightly then idled fine again , since then I could only throttle it between 1/4 and 1/2 throttle about 2800-3000 rpm , anything over that range it runned like **** !! Felt like both misfiring and fuel starvation it was really weird , usually missfire you can pin it and even with lack of power it will slowly gain rpm / speed still, and fuel starvation usually happens after a mid/heavy load in the engine then after let it idle a few seconds you can pin it again and it’ll work fine for a few seconds until the lack of fuel happen again, but my issues feels different!! Maybe both fuel and ignition problems ? While coming back at the docks **** got worse, couldn’t go past 2000-2200 rpm , over this range the engine was bugging big time , even below 2200rpm it often sounded like it was running on 3 cylinders, but again didn’t sound like only 1 cylinder was misfiring, like all cylinders randomly misfired, even at idle speeds it often and randomly ran on 3 cylinders. Took the plugs out at the docks, all 4 were pretty identical looking slightly lean but not that bad , and none of em had signs of water intrusion so I don’t think the gasket is leaking water into the cylinders, if it does it must be very minimal so pretty much untraceable
. Long story short , the guy was going through divorce and needed money right away so I offered about 60% of the price we first agreed on and he accepted!! Took the boat back home and tried to start it this morning and fired right up and idled like a champ ! Gave it a bit of throttle with some short full throttle hits and never ran like crap (I know I can’t replicate loads out of the water ) sometimes I could hear missfire .
You guys have any clue what I should diagnose first ?
Thanks
Chris
Thanks
Chris
