achris
More fish than mountain goat
- Joined
- May 19, 2004
- 27,468
Hello all,
Have a little job coming up for a friend. Pulling 2x 1984 260MIE out of a boat and rebuilding them. As was the want of the day, the port engine is LH, the stbd is RH. No big deal, yet...
We want to stroke them to 383s, and finding a reverse rotation stroker kit is like ...
The crankshaft has different oil passage drillings.. The crank seals (front and rear) are different.
So, we need to look at converting the RH engine to LH. The kit takes care of the crank and pistons, seal and rods. I've checked and the blocks are the same, we'll need a new camshaft (and timing set), and the 71C is going to need to be converted, or replaced. The hoses swap over on the seawater pump, the alternator and engine circ pump are bi-directional, and that should just about be it.. But there is one other item.
What I can't find out is if the starter motor can be converted. Is it just a brush wiring change (makes it simple to do) or are the field windings different? Please don't just say 'buy a starter from xyz (your favourite shop)'... We're in Australia, we just don't have access to the sorts of shops you do (any more)... I need hands on advice, not sales advice.
TIA
Chris........
TIA
Chris........
