91 sea ray. Shaft in distributor has play so points need to be converted to electronic. Any good resources for this? Thanks
are you sure its play, or the mechanical weights moving. rotational movement is required for the mechanical advance to work. side to side movement is the bushings.
if your distributor shaft has side to side play, you must go to NAPA and buy the two distributor bushings. bottom one is about $7, top one is about $8
and you must have your old ones out to measure the ones you need. simiply replacing the bushings and your current distributor will last another 32 years. and with points lasting as long as 20 years with normal maintenance, you are out less than $40 for the next 32 years
failure to fix the slop in the shaft and your conversion will fail
as far as conversions go, Mallory makes a good one, Pertronix makes one that is iffy based on my experiences. the conversion will cost you in the $75-$120 range
or you can upgrade the whole distributor to the delta voyager for about $350
