Intake warning sound for one second
Anthonym2
Hi everyone
Recently, while running the boat pulling a tube, the intake warning came on for a split second and then stopped. It happened twice. The amount of time that it was on was so short that as soon as I started to lower the rpm's it was over so I kept running. Engine temp and oil pressure were all normal. At what point do I worry about this? If it keeps happening is that something to be concerned about? Is this a sign that my impeller is going?
Is there anything I can do to troubleshoot that?
I have a 2007 sea ray 185 sport mercruiser I/O
Thank you
I'll assume its a Merc because its posted in the Merc section. Doesn't matter what the boat is but do need to know what motor and serial numbers are best?
What is a intake warning sound?
Maybe the alarm beeping?
Anthonym2
Yes, that is my question. The intake alarm is what is going off, but only for a split second then stopped.
achris
More fish than mountain goat
There is no 'intake alarm'. Is the buzzer sounding?
Scott06
If it is the buzzer three things can make it go off oil pressure switch , temp switch , or drive lube bottle level sensor
Earl Cordova
There are actually more codes than just those three.
You need a code reader to know what is going on.
