1972 evinrude 6hp issues
Monkeyslap79
Got a 1972 evinrude 6hp, can't get water to come out the back, replaced the water pump kit, got water hooked up to intake and get it running and water won't come out the outtake
Was the water tube installed in the exhaust first ?-----Before to installed the lower unit ?
F_R
In the first place, the water pump doesn't actually "pump" while running on a hose, it only allows hose water to get through if running. Suggest you run it in a suitable tank of water to see if it actually needs fixing.
The water intake is behind the prop on this motor.----If you used muffs what style did you use ?
kbait
Muffs are useless for diagnosing cooling system. Lake test or barrel deep enough to submerge waterpump.
oldboat1
^agree. Add that a first step is to make sure the motor is not overheating. Carefully touch the top of the cylinder head. Too hot to touch is too hot to run.
The main water intake is behind the propeller.------So put the boat in the water for testing.----Or in a deep bucket with water 6" above the water pump !----And check the thermostat as they are often stuck open.------Simple as that.
Monkeyslap79
OMG I opened it and nothings in there lol, that's why no water coming out?
Crosbyman
water should still be pouring out ...
try backflushing from the thermostast housing inlet and outlet ports
Folks often take the thermostat put when they are unsure of how to proceed.- Motor should still pump water.
oldboat1
The gasket for those is thick. Look for a BRP/OMC one -- think I've used Sierra (via NAPA) and that worked. Cover has to be torqued down evenly, and should prep the mating surfaces.
Crosbyman
the rim gasket fits all around and over the thermostat rim and sits nicely in position in the recess
