Mikeopsycho
Thread starter- Joined
- Feb 6, 2014
- 738
I will be installing a new 6 circuit 100A Blue Sea fuse panel on the transom to clean up some of the existing wiring. Right now there are 2 downriggers, 1 usb port, a wash down pump, and a bilge pump all connected directly to one or the other battery with in-line fuses. I plan to leave the bilge pump connected directly to a battery, but will connect the other things to the new fuse panel and eliminate the in-line fuses.
My question is; should I install a fuse between the battery selector switch and the new fuse block? What kind of fuse, and what amperage? I will plan to use #6 wire, and it's about a 14" run.
Thanks, Mike
Thanks, Mike
