banderberg
Thread starter- Joined
- Jun 30, 2022
- 102
The spark plugs I'm using for my 3.0L have a 0.031" gap. The engine specs call for 0.035" gap. Is that tiny difference going to matter?
No but you can gap them to .035 unless you are doing iridium plugsThe spark plugs I'm using for my 3.0L have a 0.031" gap. The engine specs call for 0.035" gap. Is that tiny difference going to matter?
The cover on the carb flame arrestor has all the information about the engine including spark plugs which it says should be "AC-MR43T". When I went to buy these, the store didn't have them and I don't recall specifically but somehow I landed on the NGK BR6FS plugs as being compatible.You should be using the plugs that your motor recommends using. Why are you using something else? They make plug gapping tools so you can set the gap on your plugs to the correct specs. It may not cause much of an issue...but why add the chance of it causing an issue?
I had thought about doing iridium. Never used them before, but sounds like they can't be gapped?No but you can gap them to .035 unless you are doing iridium plugs
This is where I found that I could use the ones I have nowYou should be using the plugs that your motor recommends using. Why are you using something else? They make plug gapping tools so you can set the gap on your plugs to the correct specs. It may not cause much of an issue...but why add the chance of it causing an issue?
They can be gapped, but you need to b extra careful as the thin wire can be damaged very easily. If you go with the Iridium, and they are gapped at .0031, I don't think the .0004 difference will affect much. Or go wit hregular plugs and set the gap to the .0035. I prefer the NGK over AC plugs anyway....I had thought about doing iridium. Never used them before, but sounds like they can't be gapped?
correct some of the higher end plugs like iridium are pre-gapped and you cant change them. Don't waste your money on iridium for a 3.0 standard ac delcos will be fine and you can replace them five times for the same cost ...I had thought about doing iridium. Never used them before, but sounds like they can't be gapped?
the first paragraph states...And the myth of not gapping iridium plug continues…google is your friend. If you still believe this, go to the Denso website, one of the industries leading spark plug manufacturers.
Installing iridium plugs
For contextthe first paragraph states...
"In most cases your Iridium Power plugs do not need to be gapped"
BR6FS are the NGK equivalent for the MR43T. They are a perfect replacement for the AC plug (I only use NGK spark plugs). 31 thou isn't going to cause any problems.The cover on the carb flame arrestor has all the information about the engine including spark plugs which it says should be "AC-MR43T". When I went to buy these, the store didn't have them and I don't recall specifically but somehow I landed on the NGK BR6FS plugs as being compatible.
Yes my 3.0 takes too long to start, requires me to nurse throttle for a while before it will idle without dying, and idles rough, shaking side to side. Smooths out if I increase throttle. I'm replacing the points with pertronix and the coil with a flame thrower, new cap and rotor, I installed a fuel water separator. If none of that helps I'll look at replacing or rebuilding the carb.BR6FS are the NGK equivalent for the MR43T. They are a perfect replacement for the AC plug (I only use NGK spark plugs). 31 thou isn't going to cause any problems.
Are you having run issues?
Chris...
That sounds like a carburettor problem...Yes my 3.0 takes too long to start, requires me to nurse throttle for a while before it will idle without dying, and idles rough, shaking side to side. Smooths out if I increase throttle. I'm replacing the points with pertronix and the coil with a flame thrower, new cap and rotor, I installed a fuel water separator. If none of that helps I'll look at replacing or rebuilding the carb.
Snake oil will always help (the snake oil manufacturer's bottom line)... ie, no such thing as 'mechanic in a can'.Chris, would adding Techron to the fuel help the problem.
