- Joined
- Apr 17, 2002
- 71,541
Ayuh,..... And both valves are closed,....The valve cover look gets close. Valves close and the mark on damper will be about 180* away. I say about because there is cam lobe variations. With all spark plugs out rotate crank by hand and have a wire or something in number 1 cylinder. Slowly crank it up till the wire is not pushed out any further, this should be close
