Horn Constantly Blows When Battery Switch Is Turned On?
Racer25
All of a sudden on my 13 year old Godfrey Sanpan pontoon, when I turn the battery switch "on", the horn constantly blows & doesn't stop. How crazy is that! I disconnected the horn, but would like to figure out what's going on...I'm sure it has to be some electrical issue. Any thoughts?
pwiseman
If that is the only symptom, you might just have a bad horn or switch/button. I would check the switch/button first. Might be a really easy fix.
440roadrunner
You need to find out if there is "only a button" or also a relay. Relay could be stuck, or a wiring problem could be holding it engaged. If "only a button" a bad switch is the most likely.
MRS
Where is O.P. did you figure it out?
Maybe 🤔 your 13 year old pontoon is just
Horny 😝.
