Mitch13
Thread starter- Joined
- Jul 7, 2022
- 2
We have a 2001 Sea Ray 210 Bowrider with a 5.0 Merc/Alpha Drive. I have noticed over the last couple trips that the boat goes into gear a little rougher then it use to and does not always want to come out of gear weather you you are in forward or reverse. Often I will have to go past neutral to get it out of forward or reverse with the button pressed. I was first thinking that I could have a cable issue but after turning the boat off the throttle moves pretty smooth through forward and reverse. Also if I pull back to neutral while underway and it does not go into neutral if I turn off the engine it will immediately goes into neutral. So I'm thinking that I may have an idle problem that is keeping the boat in gear? I did notice last night that the engine is idling around 800 RPM, anyone have any experience with a like issue?
Thanks,
Frank
Thanks,
Frank
