solar7647
- Joined
- Apr 23, 2009
- 1,218
I have a 1987 Mercruiser 4.3l 205 with high oil pressure, the details are that in the process of doing a restore/refit of my boat I purchased a reman long block from ATK. I swapped all of my tins and manifolds to the new engine and dropped it in. I added conventional 5w30 oil per the ATK instruction for break in and primed the oil pump. I got the engine running and timed properly and it sounds and runs great, I then noticed that the oil pressure at idle was 60 PSI. I allowed the engine to warm up thinking once hot the pressure would fall but it did not. I brought the throttle up to about 3k RPM and the gauge on the dash was pinned. I checked the sending unit and it ohms out at 220ohms, I checked the gauge by grounding the signal wire from the sending unit and the gauge needle pins as it should and is zero when not grounded. I pulled the sending unit and installed a mechanical gauge and it verified the 60psi idle reading and when at 3k RPM the gauge reads over 100psi. I pulled the distributor and ran the pump with a drill and can see oil flowing through. I pulled the valve covers and ran the engine at idle to verify that oil was coming from the lifters. The oil filter is a STP 3980 standard 4.3l oil filter. I have dropped the oil pan to verify that there was nothing in the pick up and pulled the pump, the pump is the High volume M-55 pump. I am planning on swapping with a new standard flow M-55 as what was on my original engine.
Does anyone have any other ideas on what the issue could possibly be, or something else I should check?
Thanks.
Thanks.
