Johnson 35e 77c outboard
sinkhole
Can anyone tell me what height on the lower shift rod is? Can you adjust height by turning rod?
sinkhole
The shift rod on your motor isn't threaded into the gearcase. What problem do you have?
Thanks for reply . I was concerned if I turned rod to raise it and if it wasn't threaded I would have more problems. Have just acquired motor and could not get it in gear. After getting your reply I reassembled and it is working fine.
The lower shift rod is threaded into the lower unit.-----I believe you turn it all the way in.
