findinghomer
- Joined
- Nov 7, 2009
- 329
Guys I am stumped and I'm not getting spark and Ignition systems are my weakness. Before I took the boat out on the lake for the 1st time this year I ran it on muffs and it ran great, So I headed to the gas station filled it up with gas and dumped it into the lake. It fired right up, but stalled within 60 seconds. Usually that's no biggie when it's cold, but this time was different when I turn the key it just cranks and cranks and cranks and cranks. Thinking I flooded it I waited a while. After a while still the same thing. So I pulled it out. The next day I decided to give it another shot because it usually will fire right up if I write-up if I flooded it and it sat overnight. Dropped it back into the lake still just crank crank crank doesn't even attempt to start. So I brought it home. After bringing in home I'm realizing I'm not getting spark. I bought a new coil , it did not fix my problem. There is a red and white lead wire coming from the Ignition module that goes to the Ignition sensor that reads 11.8 V ( Everywhere else reads well over 12 V as my batteries are fully charged on a trickle charger) but drops down to 10.3 as soon as my tester puts a load on it. Does this mean Ignition module prob? Or is it likely the Ignition sensor in the distributor? And if it is the Ignition sensor in the distributor how do you get that out of there? The engine is a 1997 5.7 , 350, thunderbolt IV ( I Believe).
I think I'm headed in the right direction but these systems are complicated for me so any help would be appreciated thank you
