jimmbo
- Joined
- May 24, 2004
- 14,096
Another old trick is to spray a mist of water into the carbs while motor is running. The mist of water vaporizes and boils carbon deposits off.
Not with a 2 stroke.
Todays update:
Humm...Doug said that it sounds like I need to rebuild the carbs.![]()
It was addressed in post #18.Humm...
Okay so Doug is addressing the running issue.
Surprised he's not concerned with the low compression reading.![]()
Carbon buildup behind the Rings is Gradual, but eventually there comes a point where the Rings can no longer compress, and when that happens, bad things happen to the Rings , Ring Grooves, and or Cylinder WallsI can't imagine how the rings could get gunked up when the engine has been running fine for several years. Beats me.![]()
Right-o. Hopefully the Power Tune we sprayed in there yesterday morning helped clean things up.Carbon buildup behind the Rings is Gradual, but eventually there comes a point where the Rings can no longer compress, and when that happens, bad things happen to the Rings , Ring Grooves, and or Cylinder Walls
Nope, I just followed the instructions on the can, which said to let it sit for 15-30 minutes, then rev it slightly and let it run 4-5 minutes.I hope you ran the engine at WOT under load, after letting it sit for an hour or so.
Times change, I guess.Back in the Day(1970s), the Procedure was spray the Stuff in there, when the can was getting close to empty, reduce the rpm a bit and Stall the Engine with an excessive amount, let it sit a couple of Hours, then go roaring down the lake, to blow the stuff out. In the 60s and 70s, OMC Engine Cleaner was a much more potent Formula, I think it was pure Carbon Tetrachloride. It really Stank, and the resulting Smoke would burn your Eyes, and Nose. It worked well though. I poured some on a badly carboned Cylinder Head. 20 minutes later, it looked like paint does when your apply those Stripping Fluids, and the Carbon just wiped off.
I actually started to do a spark test last week but couldn't see anything well enough in the bright sunlight and it was miserably hot too, so I didn't want to mess around out there much. The Chief is occupying the garage, so we're limited to working outdoors. It's the normal rainy season here, so we haven't been able to do the spark test in the cooler part of the evening yet. We'll get it done as soon as we can.Lots going on here, could you pull the spark plugs, number them and take a pic? No idle change when spraying that PT could mean a couple things. Mainly thinking no fire due to a plug not firing which could mean the switch box dropped a cylinder. A spark test may be in order.
Also after I do the power tune and let the motor sit without hitting the lake a snotty black goo will drizzle out of the prop hub.
Meanwhile, here are the spark plug pix. They're a lot dirtier after the PT treatment. They were all essentially new before that and looked that way.
They definitely look interesting. Something going on with the bottom 2 cylinders for sure. Looking pretty rich I think.
