Scott06
- Joined
- Apr 20, 2014
- 7,687
a 4.3 to V8 is pretty easy swap - one the exhaust manifolds are different and down turn elbows after the riser/elbow on top of the exhaust. Both 4.3 and V8 share the same wye pipe so pretty easy drop in. I kept my wiring harness from the 4.3 just swapped ignition modules as the 4.3 doesn't get as much advance. Drive ratio I think you can prop around one drive ratio step easily like I did. I think if you were doing 2 or more drive ratios steps you may run out of available prop pitches.I'll understand if the question is too broad and can't really be answered fully! I think Scott here has a lot of the information I'm interested in:
Scott,
This is fantastic information for me, thank you so much. This, I can definitely use if I do decide to do any more work on my Glastron in the future. Michigan Motorz seems to be a great resource for marine engines, and that's good to know that if I did swap to a V8 I would need more room in the engine compartment and need to move the blocks forward 4-5" more, and would need to also consider the exhaust headers, wiring harness, prop pitch, and ratio, in addition to the added weight of the engine.
I think, for the most part, this response contains most of the information I was looking for and can also be used in a broader sense when purchasing an engine for any boat. At least, some of the biggest considerations, that is.
Having said that a 5.7 would be over kill for a 17 ft glastron... my buddy ahs a galstron 185 with same 43. you have very preppy hops on a plane quick and has a small wake that is nice for skiing. With a 4 bbl would have a nice punch
Bottom line start with smaller projects that are within your ability and cashflow...Nothing worse than starting something and not being able to use it for years. I was into classic muscle cars from when I was 15, had a nice '65 Pontiac LeMans coupe that had 66 k on it. All I wanted was a real GTO. Sold the LeMans, bought a 65 GTO convertible project car that was beat to hell, took me 30 years to get it road worthy. Wasn't fulfillable project until I was older, the wife was back in the workforce, kids were older and I made better money ...
