Elbow and exhaust manifold inspection what do you think?
achris
More fish than mountain goat
Non-dry joint elbows. Warm the engine, retorque the elbow and manifold bolts while the engine is still warm.
Dry joint elbows. Warm the engine, retorque ONLY the manifold (to head) bolts. Do not retorque the elbow bolts.
Chris...
Franco_boater
Ive got it Thanks Chris m
But question regarding torque exhaust Manifold to heads. Page 7B-2 says 34Nm but Page 7B-9 says 43Nm …(??) manual #37
Thanks
Scott06
Thanks
I don't know which is correct but converted to ft lbs it is 25 &31 ft lbs respectively which is not much difference- either will work, but if I didn't have a torque wrench I'd use a calibrated elbow ...
Ayuh,..... I've got several torque wrenches, 'n I still use my calibrated elbow for those bolts,.....
Pretty darn snug, vs: Good 'n Tight on others,....
