Noise??
Jmac127
Can someone tell me what this noise is from my engine? Keys off, all electrics off.
  • IMG_3849.MOV
Jmac127
After some videos, I think so. Maybe a stuck float switch. I will check that tomorrow.
Ayuh,..... Welcome Aboard,..... The bilge Pump runs on a float switch,....
The bilge blower is run by a dash switch, 'n is mounted on the transom, just aft of the port-side exhaust manifold,....
Jmac127
It’s not the blower that switch is manually controlled and I can definitely shut it off, I’m thinking float switch. Headed to check shortly. Thanks for the reply.
Jmac127
Did some process of elimination. Not blower, another small red wire engages the noise, almost certain it’s float switch. The problem now is I can’t freakin get to it.
