Leak above drive
TC10
I took my boat out yesterday and noticed my bilge filling up quick. Today I had it on muffs at home and came across this leak. I can’t determine what it’s from. I was thinking bellows but not sure. Any help would be appreciated.
  • IMG_2566.MOV
achris
More fish than mountain goat
There's no video, only audio... Can you upload using a different format (*Apple doesn't play nice with anything but apple, and even then it's dodgy)...
Chris......
nola mike
Chris......
I'm able to see video. Looks like it's coming from above the bellows
achris
Ok, I had to download it, but I can see it now (had to use a player that speaks 'apple')...
If it's happening when the boat's on the trailer, then It can only be a corrosion hole out of the side of the water inlet...
TC10
Thank you for taking the time to see the video. The video was taken while on the trailer. I’ve had issue after issue all season. I think it’s time to live in from it as much as I’d hate to. Thank you all again.
achris
"Live in from it"? What does that mean?
TC10
Ha sorry. Autocorrect. I meant move on from it. Getting frustrating. I spend more time diagnosing and fixing than I do on the water.
driz
If it’s leaking in while not sitting in the water like on a trailer then that has to be coming in from your cooling intake. Your water pump is sending it in.
Take a good look at your Small rubber hose above the bellows that feeds your raw water cooling . Another Culprit could be a misaligned, crushed or missing O Ring where the leg bolts against the inner half of the outdrive. If that’s messed up you’ll have high pressure water pumped in just like that from the water pump.
Scott06
Bellows can’t leak when boat is not in water it is cooling water from crack in hose or plastic water tube that goes through transom is cracked
TC10
I recently had my outdrive serviced, could a bad O ring or not properly placed O ring cause this much of a leak?
achris
No. Where that leak is, there is no o-ring or gasket.
TC10
Ok thanks, wishful thinking. From what you can see does the hose need to be replaced or something else. I can't find much as far as repair videos on youtube. If its something I could do myself Id rather do that. All my local shops are so backed up if I wait for one of them to be able to look at it the season will be pretty much over.
achris
Had another look at the video. There's a very remote chance it's the water tube itself.
If you have facilities, pull the drive, lift the engine out of the way, then you can get a good look at it. You don't need the engine running to test it, just push a garden hose into the water inlet on the bell housing and you should see it leaking.
Maybe try videoing from a different angle?
Chris...
