2002 350 Mag Mpi, no spark on cylinder 2 and 3
whatsalad
Help, I did a tune up, serial L675597 , Cap , rotor, trigger, fuel filter, plugs, Boat Starts for 10 seconds then dies, it will start right back up and die. If you throttle it will run but very rough, I have diagnosed it down to something not Firing cylinder 2 and 3 across from each other on the distributor ? the terminals on the inside have no marks on them as there is no spark being sent.
Very Strange.
Thanks, Dave.
2002 Centurion Response 336hrs
whatsalad
Thunderbolt ignition? Somebody put 6 cylinder rotor on it?
The rotor does have just 6 tabs, That must be the problem, it came as Sealed mercruiser cap and rotor? the cap is 8 cylinder and the rotor 6?
whatsalad
Well , Thank you, I have been on this for 2 weeks. Your the Man !
