jimmwaller
Thread starter- Joined
- Nov 30, 2013
- 274
Hi all,
I have an older mercruiser 165hp from... my boat is late 60's but the engine was replaced. I think the engine is early 70's somewhere? It's an inline 6 cylinder GM. It has an old pre alpha drive (MC-1, to be exact). So my problem is, everything works great 98% of the time. It pops right into gear and drives well. But maybe 1-2% of the time (so basically never, it'll happen maybe once over a day of boating), I'll do what I always do and push the throttle forward and the engine will rev but it just won't pop into gear. It doesn't make any noises or anything, the throttle goes forward and there's not grinding, no nothing.... it'll just go forward and there's no pop where there's supposed to be a pop and then the engine will rev but of course the boat doesn't move.
This usually lasts for about 60 seconds, and then all of a sudden it'll be fine. Throttle goes forward and it goes into gear and drives completely fine. So I'm just looking for input on what could cause this and how I might be able to fix it.
Other considerations: I did put on a different drive. It's a slightly smaller MC-1 so the gear ratio is a little different. Went from the drive that was on there when I bought it (so I assume a 165hp drive) to a 120-140hp drive. Iboaters have told me that my old drive was a 1.84:1 and my new one is a 1.98:1. I'm not sure if ratios and/or a smaller drive would affect the shifting but I thought it was worth mentioning. Any guidance appreciated, thanks in advance!
