Hello. I am in the process of diagnosing what could be wrong with my boat. I am not getting fuel to the carb.
Things I have completed/diagnosed:
-Bad starter. Replaced. Works flawless.
- Replaced slave solenoid
-checked for 12V from purple/yellow wire from starter solenoid while cranking engine over (since there is no power to fuel pump when key is in ON position. Carbed engine.) Yes. There is power.
-direct power to fuel pump and it turns on and pumps fuel to carb
My question. How does the starter solenoid keep feeding power to the oil pressure sensor once the key turns back from START to ON? I have a voltage of 10-12V while cranking, but drops to zero after engine cranks over and it ends up stalling due to no more fuel. (I put fuel in carb to get it running for a few seconds) I feel like I am missing something here. I can’t even test to see if the oil pressure switch is working correctly due to no power reaching it once key goes back to ON…?
Thanks for the help in advance!
