2003 Mercruiser 4.3L, 2 bbl carb.
Engine serial # OM643729
Engine hard to start after the boat has been sitting for days.
After it starts, it runs fantastic and will restart just fine with minimal cranking even after anchored out for hours.
Ignition wires, plugs, distributor cap, ignition sensor replaced a few years ago.
I checked under the distributor cap and it looked good. Very little tarnishing. I did clean it anyway.
New starting battery.
I suspect the choke.
After sitting in my driveway for 3 days, I looked at the choke and it was not fully closed.
I turned the key to the "on" position and moved the throttle fully open and back a few times. There was definitely gas in the carb, but the choke was still not fully closed. It had about 1/4" or more open gap between the butterfly and carb throat.
I tried loosening the three screws and rotated the choke adjustment, but the butterfly stayed in the same position.
There are two wires connected to choke adjustment. One (+) connected to the center and the other (-) connected to one of the three screws holding the adjustment tight. Is that the proper location for the (-) wire? Seems like not the best place to get a ground if you ask me.
So, I guess what I'm asking is the proper procedure for adjusting the choke when cold and if the butterfly should be fully closed when cold.
Also, when should there be power to the choke adjustment wires? Are they energized when it's cold or when it's hot? How does the ignition system know when to energize these wires?
Sorry for the winded post, but I wanted to make sure I give as much info as possible.
Thanks as always.
Joe
Thanks as always.
Joe
