They do not make a .060 oversize...040 and .044 are max. Why would you want to bore that big? If cylinders need .060 to clean up that block is junk. Even if you could go .060 you cannot adjust ECU fuel flow with a stock unit, you would have to use an aftermarket ECU and boring will not add noticeable HP. . On a stock ECU motor I will only bore .015 or .020 oversize.
