btclark0316
Thread starter- Joined
- Jun 26, 2022
- 9
So I have a 1999 mercury 150EFI. I have had to replace several things on it such as, repair leaking VST, switch boxes, trigger. The motor was missing at idle and wanted to die and cut out all through the mid range. It would run good on the top end if I could get there without it dying. As I was troubleshooting it I noticed that pulling any port side plugs at idle did not affect it. I started with switch box and then changed trigger after in hopes of fixing the issue. I have checked the stator and it is good. I have reset the time to the factory 20 degrees and adjusted idle speed. The boat is idling great out of water and hitting on all cylinders out of the water. It will also rev to the moon and back out of water without any cutting out. I put it in the water and, I can barely keep it idling and the cutting out is worse. It will scream at the top end when I get it there but it won’t run for long. Any ideas sorry for the long post, thanks in advance.
