ForcedError
Thread starter- Joined
- Jul 24, 2022
- 16
In the process of a complete rebuild on an 87 force 125. But there is a catch. The pistons bores seem to be 3.375... I called a parts supplier and he said someone likely changed the block out to a newer year and he is suggesting a rebuild kit of 91-94. My question is, what caused some of the pistons to melt down this way? I noticed some of the reeds were not closing all the way. I see some daylight though them. They are not chipped but open a bit like a few specs of sand are holding them open. I just bought this turd and couldn't get it to run right so I got aggressive and found that 3 cylinders were 120 psi ish and one was 90. I decided to rip it apart and found that all four pistons has cracked rings and damage to the pistons. Amazed it ran at all. I also found a Crack in the plastic water pump housing. I'm asking what definitively caused it as I don't want to recreate the same issue. thanks in advance!
