wyelkhunter73
Thread starter- Joined
- May 13, 2021
- 7
Question about outboard motor mounting height. I got a 2003 180 combo this spring and had a newly rebuilt Merc 200 hp EFI put on it. The motor was mounted to where the bottom of the cavitation plate on the motor is 1.25" above the bottom of the boat. When I trim the motor at cruising speed or faster it seems the bow of the boat barely comes up speed and RPM does not change. The prop never cavitates either even at full trim. Is this normal for this type of boat? I am only getting 5000 rpm WOT, I know that is low but I want to make sure motor is set right before I go about changing props. My previous boat was an 18 foot aluminum and when trimming the motor I could really tell a difference in speed and RPM.
