saltchuckmatt
Thread starter- Joined
- Jul 19, 2019
- 3,387
Hi, I have a 2000 Yamaha four horse four stroke. Doesn't seem to be peeing much water but runs fine, at least off the boat and in a tank. Do these motors not run much water out the telltales? Went ahead and pulled the lower unit thinking the water pump was spun and everything looked brand new. Put it back together which by the way wasn't very easy, I sure prefer evinrudes for doing that little job, but that's just a side note. So does anybody have an older four-stroke 4 horse that not much water is coming out of the pee hole? I pulled the hose off the thermostat while it was running and there was a pretty good amount of water. But that hose doesn't go directly out the back like I'm used to it goes back into the block. When I blew air into that hose I got lots of bubbling below the water down near the prop so I'm wondering if that pee hole just doesn't show all the water or if something else is messed up like the draw tube or something. This is a tough one I'm sure but if anybody knows what's going on please let me know. Be interesting to know where the water is circulating through that particular motor. Thanks in advance.
