CLi87
Thread starter- Joined
- Sep 21, 2018
- 237
My distributor and ignition coil wires all go into that module mounted on the exhaust elbow. So I don't need to worry about putting it in base timing mode, just run it at ~700rpm (in the water I'm assuming?) then set it to 8 BTDC?Your 454 doesn't have thunderbolt 5, it's a 4 that has no base timing mode. Someone referenced an mpi style which no 454 came with.
Just set the base timing to 8 btdc and you're set. And do check total advance, not a huge deal with the 454. It can handle up to 43ish naturally aspirated with no consequences
