Mercruiser 7.4 Gen V Trim Sender Wiring
CLi87
I've almost got everything on my engine put back together but i'm having a hard time figuring out where the trim sender wires attach to, the only wires left that aren't hooked up to anything are the purple and blue coming from one harness and the black and black/white stripe coming from another harness. I have 2 sets of trim sender wires, does one connect to each set of wires? Anyone have a wiring diagram handy for a 7.4 Gen V?
dubs283
The two male end wires connect to the blue and purple wire female connections at the trim pump wiring harness. The male and female end wires connect to the sender wire ends at the engine harness. Usually located at the aft side of the intake. Look for corresponding male/female bullet connectors colored brown/wht and black
CLi87
Thanks!
