N over my head
Thread starter- Joined
- Jul 14, 2022
- 25
While cutting out my floor in my fiberglass boat, I used a multi tool about a quarter inch out from the edge of the hull to cut old tie in where plywood floor connects to hull. It left an edge that is was wondering how much of that I needed to grind off. Does it need to be feather edged smooth with the hull before installing new floor, or just taken down so as it’s not a lip sticking out in the way of the new floor. I guess what I’m trying to say is, when plywood floor was installed at factory it was butted up to the hull. It was then shot over with a chopper gun to tie plywood into hull. This left a thicker hull above plywood floor than below. Should this edge be taken down flush with the thickness of the hull above the old wood on floor, or does it need to be feathereded in flush with fiberglass that was below the old wood?
