tablerockboater
- Joined
- Apr 23, 2005
- 232
Speaking of anodes (elsewhere), I just noticed that the new-to-us 2008 Sun Tracker Party Barge's Merc 50 does not have a trim tab anode on it.
Should it?
Should it?
What does it have under there? Is it a flat plate? Or does it look like something is missing?Speaking of anodes (elsewhere), I just noticed that the new-to-us 2008 Sun Tracker Party Barge's Merc 50 does not have a trim tab anode on it.
Should it?
Some have to be replaced with the flat one due to prop pitchSpeaking of anodes (elsewhere), I just noticed that the new-to-us 2008 Sun Tracker Party Barge's Merc 50 does not have a trim tab anode on it.
Should it?
Customize with a hacksawHi. I’d imagine in this case, it’s because often on boats like this, people prop them with big diameter props to get the best out of the application. Bigger diameter props will hit the standard trim anode fin. There is a cut back one you can buy…or the flat one without the fin at all. On my outboard, even the cut back one didn’t clear the prop. So had to get the flat one.
Haha. The prop nearly did that job for me !! I actually did just that…but ultimately ended up just biting the bullet and getting a hydraulic steering kit. All was well afterwards.Customize with a hacksaw![]()
Kinda what I thought, that it looks like the anode will be in the way of the prop. (Of course, it wouldn't be for long!) I will know soon, since the anode arrived yesterday and I'll be doing the test drive, to feel the pull later today. The boat is new to us, so I don't know if the prop is original.Hi. I’d imagine in this case, it’s because often on boats like this, people prop them with big diameter props to get the best out of the application. Bigger diameter props will hit the standard trim anode fin. There is a cut back one you can buy…or the flat one without the fin at all. On my outboard, even the cut back one didn’t clear the prop. So had to get the flat one.
