2007 E-tec 115hp. Cooling water question.
mjbuck
I have a 2007 E-tec 115hp outboard. It has been a great motor. Of late, I have been having intermittent cooling issues. I did find that most of the problem was corrected when I changed the water pump/impeller with a new kit. A good flush of the cooling hoses took care of the rest. But, while doing routine maintenance I noticed water leaking from the side of the exhaust housing while the motor was running. I tried to load a 7 second video to show the exact location and how much water was coming out, but I could not get it to load. Nor could I get a photo to load. So, I will explain the exact location. The leak is from both sides of the lower front of the exhaust housing, just above where the lower unit separates from the housing. Looking at a parts diagram, the area where it is leaking is called the lower mount (part # 5005694). This part has a cover with 4 bolts that holds the cover in place over this part. Water is coming from this area. I have checked for cracks or broken hoses, etc., but can find none. I have worked on my motors off and on over the years,but am by no means an expert. I'm guessing the water I see leaking is from the cooling of the exhaust.... maybe.
Crosbyman
check in with the ETEC owners board also ....
the ETEC board is where world wide ETEC users share problems .....and it has a good search utility
saltchuckmatt
Not sure if this is a normal thing or not but I have a 2009 115 Etec. I to have some weeping between where the foot bolts to the mid engine or what might be what your describing. I thought it was odd but I'm having no problems. Not sure it's the same area as yours though. When I type in 5005694 I get a rubber bushing.
saltchuckmatt
It used to be e-nation but it went tits up after the fall of Evinrude. I think it now runs under Barnacle Bill or something.
