Kola16
Thread starter- Joined
- Jun 23, 2019
- 229
Hello all. I need some schooling on how the RPM signal is generated. I just replaced the carburetor with a Holley Sniper EFI system on my Mercruiser 260 setup (old carbed-style GM 350). My tachometer and the Holley Sniper unit will jump up and down in RPMs when that is not what the engine is actually doing. From 800 RPMs to 4000 to 400 to 2500 and all over the place.
I have a Pertronix Ignitor in my distributor that runs to the positive and negative side of my coil. When I had the carb on, it did not matter what the tachometer was reading since the fuel delivery was regulated by the air flow through the carb. But now the negative side of the coil is where the Holley Sniper system gets the RPM signal to inject fuel into the system. Because the tachometer bounces periodically, the Holley Sniper thinks it needs to inject fuel when the tachometer goes up, even though the throttle is at idle.
The Holley Sniper has its own display with an RPM reading and it bounces around concurrent with the tach on my dash. When the tachometer is not bouncing around, it runs great.
The tachometer only just started jumping around at the end of last summer when I had the carb on it. It seems to stop bouncing around after it has been running for a while. I tried unplugging the tachometer on my dash to see if that helped and it did nothing. I put new plugs and wires in it and nothing changed.
So how does the RPM signal work? Every time a spark goes off in each cylinder it counts or something? Could it be missing in a cylinder?
How is the system grounded? Can I run a ground from the negative of the coil to my common ground or is that a bad idea?
Could the Pertronix Ignitor be sending a bad signal? I am not sure how the Pertronix Ignitor works...
I'll get some pictures and video up here by the end of today. Please help! Thanks!
