50hp electric start evinrude reverse issues
Hawk73
My 50 horse Evinrude motor worked before I took it into the shop in reverse I brought it home put it back on my boat and all it does is Chatter now I thought it might have been the cables but I disconnected the cable from the shifter lever and tried to do it manually from the shifter lever and it just jumps back and forth any ideas from anyone out there
You are sure it is not a 1981 model ?----Check the gear oil.-----I would remove lower unit and check shift rod height.
Hawk73
The title says 1985 i I just changed the oil and set the shift rod to just a little over 53 centimeters
The model # tells me it is a 1981.----Time to take the lower unit apart for inspection and repair as needed.
In some states a motor is considered an item that needs to be titled !
Hawk73
Its tilted apparently thru the years the information on the title got changed
