Thermostat Location on 1993 Mercury 2 stroke/ 4 cyl (115Hp)
RAZLEO
I have the 1990-1993 3-275HP Mercury Outboard Shop Manual and there is no mention of a thermostat? Does this mean these engines did not have one? My engine overheat (?) alarm is going off
Dave1027
Which motor are you asking about? 115 hp or a 3 - 27 hp? The 115 hp has a thermostat. It's on cylinder head/cover top left.
Dave1027
Unfortunately it does not have any temp gauge. It's a 1990 Sea Pro that I just bought recently
Just keep in mind, these motors are more likely to have the warning module go bad than the thermostat. Have you checked the water impeller? That is also more likely.
I see you corrected your initial post. A 3 -275 HP manual is way too generic. If you are planning on keeping that motor, you should invest in a Mercury shop manual that is specific to your motor.
RAZLEO
Thank you so much Dave1027. You have been a great help! The warning horn is not on all the time...........just intermittently. Do I need to take it apart to check the impeller?
Dave1027
To check/replace the impellor you need to unbolt and remove the lower unit. The process should be in the manual. It is in the Mercury shop manual. There are probably you-tubes that show you how.
