drkilldrmz
Thread starter- Joined
- Jun 17, 2003
- 42
Hello group. I have a 75, 25hp evinrude I have been rebuilding, and I have it to running condition, however, it's sneezing at all RPM's. Rich, lean dont seem to affect it. Carb plate is fully closed at idle, opens right between the armature dots. Points clean, adjusted to .20, nice spark. No obvious oil from the upper seal. Carb ultrasonically cleaned, with plugs removed, replaced. Replaced the powerhead base gasket when I replaced the shift lever. I'm getting a little lost now as to where to check next. Also, on the exhaust cover, there is an open, threaded hole not obvious on the schematic. Does this serve a purpose?
