Kubaat3lover
Thread starter- Joined
- Jun 6, 2019
- 443
Good morning guys,
I would like to ask You about some advice from You guys when replacing the intake manifold gaskets.
Finally I’ve found the leak in my 4.3L from 2005,
The oil leaks from the intake manifolds and I have to replace the gaskets I want to buy felpro replacement gasket. It seems pretty easy but in manuals and service bulletins I’ve found some colliding information.
I have to work on my boat on my own and with your help I’m doing pretty well (you’re the best guys) so here are few questions
- Serial number is
should I use manual 25?0w326935
- Now I’ve got white/gray silicone sealer but with replacement FelPros there is a black silicone. Is it better to use Ultra Gray Permatex or ultra black ? What do You think? When applying RTV sealer should I put it 1 layer on the gasket only?
- Should I put Perfect seal only around water ports or whole gasket smear with perfect seal according manual? I’ve found video (( )) where this guy put silicone around ports
- To remove distributor, do I have to put the cylinder #1 into TDC position or it doesn’t matter?
- there is note about metal restrictor on the water port in the manual?
