Lou C
- Joined
- Nov 10, 2002
- 14,549
Impellers will not suck water with a column of air in front of it. They have to be immersed in water to pull water. Even with outboards if you run in a garbage can (like we do with our little Suzuki) the water level has to be above the top of the water pump.
On land use muffs as noted or else you will burn up impellers overheat your engine & rubber exhaust hoses.
