I have a 1998 Falcon 2500BR with a Mercruiser 454 MAG EFI. Since I got it a year ago it has always ran a little rich (black soot on back of boat and slight smoke at times). Decided to install new spark plugs and used NGK BPR6FS plugs. Took it to the lake for the weekend and ran for about 5-6 hours with no issues.
Since I got the boat the temp gauge never worked (always said as cold as it could read) so decided to change the temperature sender for the gauge(did nothing with the one going to the ECU) and while I was doing it decided to install and new 160 degree thermostat. When I went to install the thermostat I found there was not one in the housing so had been removed by the previous owner.
Now the boat starts and runs great cold but when it gets to about 150-160 degrees it starts to miss and sounds terrible. Also, when warm it is very hard to start- cranks for ever and then when it does fire sometimes doesn't stay running long and sounds terrible like running on half the cylinders.
Anyone ran into this and have any suggestions what to check??
TIA
TIA
