use a voltmeter ... troubleshoot the coil voltage .Have a 2000 4.3L mercruiser will turn over but wont fire...no spark...change coil but still no spark....
Likely a thunderbolt ignition. A few reasons why no spark but most likely is ignition sensor in distributor. Need to verify no spark then follow the troubleshooting guide posted in the stickies.change coil but still no spark....
replaced that sensor still no spark...leaning towards ignition switch any input?Likely a thunderbolt ignition. A few reasons why no spark but most likely is ignition sensor in distributor. Need to verify no spark then follow the troubleshooting guide posted in the stickies
use a voltmeter ...replaced that sensor still no spark...leaning towards ignition switch any input?
Yeah, follow the troubleshooting guide before throwing more parts at it.replaced that sensor still no spark...leaning towards ignition switch any input?
forums.iboats.com
