Tahoe Mike
Thread starter- Joined
- Aug 5, 2019
- 3
1995 Four Winns with 5.8 and Volvo Penta SX outdrive. Engine overheated first time out, idled thru no-wake zone but once we accelerated engine overheated and shut down. Pulled the raw water pump, rubber impellor blades in pieces so I replaced the impellor re-installed. Large hose on pump seems to be intake from outdrive water slots. Backflushed with water hose and flow good from pump intake hose to outdrive slots. With muffs installed and water flowing into outdrive slots NO water coming to pump from intake hose ???
Tried running engine with muffs for about a minute still no water coming thru intake hose to feed the pump. Someone replied previously to my inquiry and said that there is no "pump" in the outdrive that sends raw water to the raw water pump. I can accept that but why isn't water reaching the pump when I'm sending water into the system thru the muffs?
I was hoping to run the engine long enough to hit operating temperature 150-160 degrees and observe the cooling system was operating before putting it in the water but with not water getting to the raw water pump from the muffs I don't see that scenario working.
Outdrive is in down position while I was using the muffs - still no water to pump
Please advise on what I'm not seeing here Thanks
