puzzledprofessor
Thread starter- Joined
- Aug 26, 2011
- 22
Years ago I bought a 1953 JW 10 as a parts motor for 30 bucks. This week I decided to try and get it to run. Did all the normal stuff, coils, points condensers, wires and carb kit. I bought a cheap carb kit and the valve seat didn’t thread all the way in so I had to use the old seat and needle. Got it running, but gas was draining out of the front of the carburetor. Took the carb off, cleaned it again, put in a different float, reset that float and put it all back together. Started and ran pretty well. No leaking gas. Took the recoil off to check the points gap. The next time when I started it gas was draining out of the carb again. So am I correct in thinking that at this point it has to be the needle and seat or the something with the float. Any thoughts would be greatly appreciated. Thanks.
Vance
Vance
